16" Ford Ranger rims on a YJ?
Discussion in 'Wrangler YJ (1986-1995)' started by YJJLU 9218, Oct 17, 2018.
  1. Oct 17, 2018 at 11:26 AM
    YJJLU 9218
    YJJLU 9218 [OP] Member
    been looking for some rims, found some 16 in off of a Ford Ranger would these go on my yj?
  2. Oct 17, 2018 at 11:34 AM
    If the Ranger wheels have a 5 x 4.5 pattern it should bolt up but the next concern is the optimal backspacing or offset.
  3. Oct 17, 2018 at 2:11 PM
    YJJLU 9218
    Pardon my ignorance, is the offset the distance that the actual tire sits back toward the inside the Jeep? Usually I have my grandson to school me on such matters but since he joined up I’m on my own lol
  4. Oct 17, 2018 at 2:21 PM
    You are describing backspace. Offset is where the mounting service of the wheel sits in relation to the center of the wheel as it rolls. When looking for clearance of suspention components backspace is the better measurement to follow. Here is a video of backspace vs offset from discount tire.
    https://www.discounttire.com/learn/...mMk6h5NU8Jv74c_4VqCL1R-dk4Pi971hoC2T8QAvD_BwE
  5. Oct 17, 2018 at 2:29 PM
    YJJLU 9218
  6. Oct 17, 2018 at 2:30 PM
    The center bore hole may be a tad small but can be filed down to work.
    1981-08 FORD RANGER 2WD (same for 4wd)
    [​IMG] Bolt Pattern: 5 X 4.5
    [​IMG] Stud Size: 1/2-RH
    [​IMG] Hub Center Bore: 70.3
    1980-06 JEEP WRANGLER
    [​IMG] Hub Center Bore: 71.5 [​IMG] Offset: M
  7. Oct 17, 2018 at 2:53 PM
    As noted the Ranger center bore hole is smaller thus I wouldn't waste my time making a hub centric into an un-hub centric. But to each their own.
    I like my holes nice, uniform and smooth.
  8. Oct 17, 2018 at 3:04 PM
    :rofl::bananadance:
    aggrex[QUOTED] and boondoc89 like this.
  9. Oct 17, 2018 at 6:47 PM
    Humm....some thing tells me we went off topic here. :eek:. Just an observation. :notsure:
    aggrex[QUOTED] likes this.
  10. Oct 18, 2018 at 6:49 AM
    YJJLU 9218
    Just Jeep people Being themselves :anonymous:
