1983 CJ7 Steering Column
Discussion in 'CJ' started by PDiddyT, Aug 21, 2020.
  1. Aug 21, 2020 at 3:17 PM
    PDiddyT
    PDiddyT [OP] New Member
    1983 CJ7
    My steering column has a plastic ignition area. I believe this is pretty common. Can't just find the ignition housing. Looks like I'll need to buy a whole steering column. The replacements I have found all use a sleeve over to connect the steering column to the steering actuating linkage. Sorry if I'm not using the correct lingo. My steering column uses a spline type connection.
    Does anyone know a "work around". To just buy a new steering column is almost $1000.00
    I'd like to avoid that.
    Is there an alternative steering column that will work? I've heard there may be GM steering column. Is there a vendor you would ask?
    What would you do?
  2. Aug 21, 2020 at 4:40 PM
    I would first suggest a local junkyard. Take your old parts down or take pics and dimensions. Then there are specific Jeep junkyards like this one:https://www.jwjeep.com/.
    LYFZGOOD likes this.
  3. Aug 21, 2020 at 5:03 PM
    Stix
    Stix Member
    As JB said. Look for some local yards specific for your cj7 and you’ll find one or two. eBay and Amazon work nice too.
  4. Aug 21, 2020 at 5:05 PM
    Stix
    Stix Member
