1997 jeep grand cherokee limited
Discussion in 'Cherokee' started by twentyoneaj, Oct 5, 2018.
heat air from dash vent only. will not change to defroster or floor. any ideas?
  1. 1
    0 vote(s)
    0.0%
  2. 2
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Oct 5, 2018 at 11:13 AM
    twentyoneaj
    twentyoneaj [OP] New Member
    1997 limited
    none
  2. Oct 5, 2018 at 12:10 PM
    I am going to guess it could be the door that changes the vent settings is stuck/broken or the switch that changes the settings could be broken.
    If it was just blowing out of the defrost vents I would suggest a possible vacuum leak.
    The vents wouldn't change on my XJ and since it was stuck on defrost I thought it was a vacuum leak but after not finding any I swapped in a used switch and was good to go.
  3. Oct 5, 2018 at 3:38 PM
    Welcome to the site!
