1999 TJ REAR WINDOW ZIPPER
Discussion in 'Wrangler TJ (1996-2006)' started by brownbill, Sep 20, 2020.
  1. Sep 20, 2020 at 2:51 PM
    brownbill
    brownbill [OP] New Member
    1999 JEEP WRANGLER
    I now own a 1999 Jeep Wrangler that given as a gift. Repair in general is not that hard. I installed a new soft top and messed up the rear window zipper. There are two zippers how in the world do you start them. It looks like both zippers are to be connected together on left side. Should the zippers be on the window or top? My real problem is how to start the zippers!
    Thanks for the greeting
  2. Sep 20, 2020 at 3:32 PM
    If I’m following you correctly the zipper is on the top and the window inserts in the top and should zip from left to right that is the way mine is on my 98 wrangler. You may have to work with it a little bit to get it started works better in warm temperature than it does in cooler temperature
  3. Sep 25, 2020 at 5:01 PM
    TJ4me
    TJ4me Active Member
    2001 Jeep Wrangler Sahara
    Can you post some pics so we can help figure it out?
    A hair dryer might help...use it gingerly...
    LYFZGOOD likes this.
  4. Sep 25, 2020 at 6:39 PM
    brownbill
    1999 JEEP WRANGLER
    Thanks, just received new top. I am new at this but I think I will be O.K. I replaced my upper door skins with ease. I used a old paint roller extension handle (wood) to move the last corner on the frame. Worked great!!!
