2.5 Rough country springs on a TJ
Discussion in 'Wrangler TJ Builds (1996-2006)' started by LYFZGOOD, Mar 9, 2022.
  1. Mar 9, 2022 at 7:33 AM
    LYFZGOOD [OP] members
    Question with this small of a Lift would you need to change the sway bar links ends or would stock be OK??
  2. Mar 10, 2022 at 9:28 AM
    @LYFZGOOD . At ride height. Your sway bar ends should be parrell with the ground. Or slightly pointed up. They should not be pointing down. So you may have to get longer end links or adjustable end links.
  3. Mar 10, 2022 at 10:10 AM
    Thanks ​
  4. Mar 10, 2022 at 1:10 PM
    Agreed….adjustable end links make sense after a lift kit which could “settle” a bit after a period of time and need adjustment.
  5. Mar 10, 2022 at 2:39 PM
    Thanks. I knew I’d get the answer.
    Jeep Ride and JKBob 25 like this.
  6. Mar 19, 2022 at 4:49 PM
    Jeep Ride
    Jeep Ride Member
    Op what part of WV you from? I'm in Kanawha County .
  7. Mar 19, 2022 at 8:50 PM
    Harrison county. WVU.
    Jeep Ride likes this.
