2001 TJ rod knock or flex plate issue HELP
Discussion in 'Wrangler TJ (1996-2006)' started by Krisryanl, May 5, 2019.
  1. May 5, 2019 at 12:06 PM
    Krisryanl
    Krisryanl [OP] New Member
    2001 Jeep TJ 4.0
  2. May 5, 2019 at 12:22 PM
    DustStorm4x4
    DustStorm4x4 Well-Known Member
    04 LJ
    It sounds like it gets faster as you rev the engine. It sounds like a rod knock from what I’ve read. :( How many miles does it have?
  3. May 5, 2019 at 12:25 PM
    Doesn't quite sound like a rod knocking . Take the Inspection plate off and turn the engine by hand to check the flywheel. It could be a rod knocking or piston slap . It just seems to fast. My wife's 4runner has a rod knocking . That's why it's been parked for 2 years.
  4. May 5, 2019 at 12:27 PM
    It has a weird hollow sound maybe more like piston slap. Either way it ain't good . Did you run it low on oil? Have you been very high reving it?
  5. May 5, 2019 at 12:28 PM
    Mine has noisey lifters sometimes on cold mornings. But it don't sound nothing like that.
  6. May 5, 2019 at 12:32 PM
    Also welcome from Texas . Don't sweat man if it has a 4.0 there are lots of them in wrecking yards at a reasonable price. Xj,yj,and tj used that motor I believe. The ones before 03 had problems with inferior materials in the pistons. A lot of them the skirts cracked . I think there might have even been a recall.
  7. May 5, 2019 at 12:34 PM
    People smarter than me will chime in on this soon enough.then you can get a more solid answer . It ain't the end of the world regardless your Jeep can live on. Lol
  8. May 5, 2019 at 2:22 PM
    Krisryanl
    2001 Jeep TJ 4.0
    Appreciate the replies I picked up this Jeep few days ago for a decent price just wondering what to do motor swap or rebuild this . And if there is anyone that knows if the 98 xj block would bolt into my 01 head ?
  9. May 5, 2019 at 2:25 PM
    Krisryanl
    2001 Jeep TJ 4.0
    It has 150k
    DustStorm4x4[QUOTED] likes this.
  10. May 5, 2019 at 5:38 PM
    DustStorm4x4
    04 LJ
    Yeah I had some lifter noise the other day. Changed the oil and it went away. I was scared it was something serious but it sounds like common problem on these engines. It sounded nothing like this though.
  11. May 5, 2019 at 5:45 PM
    Lucas oil treatment helps
  12. May 5, 2019 at 6:44 PM
    Welcome @Krisryanl i've been fortunate not to experience such a distinct sharp metallic tap from the engine. My guess is a collapsed valve contacting the piston. It's definitely not a good sound and probably won't end well.
  13. Jun 10, 2020 at 12:39 PM
    Oldfaurt
    Oldfaurt New Member
    2002 Jeep TJ 4.0L
    4" lift
  14. Jun 10, 2020 at 3:38 PM
    With careful use of a stethoscope, a suspicious noise location can be detected.
