Largest tire without a lift on an 06 Commander
Discussion in 'Wheels & Tires' started by Goodfellas, Mar 25, 2017.
  1. Mar 25, 2017 at 3:38 PM
    Goodfellas
    Goodfellas [OP] Member
    2006 commander
    I am wondering if anyone knows what the biggest size mud tire i can fit on my 2006 commander without the lift. Thank you
  2. Mar 26, 2017 at 7:45 PM
    welcome! What size do you have on now?
  3. Mar 27, 2017 at 6:36 AM
    Goodfellas
    2006 commander
    They are the stock tires 245 65r17
  4. Mar 27, 2017 at 7:19 AM
    I would think that a 265/65/17 would fit without a lift, but you might want to do a test fit first.
  5. Mar 27, 2017 at 7:44 AM
    Goodfellas
    2006 commander
    Thank you very much
  6. Mar 27, 2017 at 7:56 AM
    My Buddy at Discount tire says the largest tire that he says would fit would be 275/60r17. This would be similar to the tire Chris mentioned above.
    275/60r17 = 30x11x17
    265/65r17 = 30.5x10.5x17
  7. Mar 27, 2017 at 7:58 AM
    Goodfellas
    2006 commander
    That helps alot thank you man, now i hope he is right because i am ordering online and wheels seperate. Thank you
  8. Mar 27, 2017 at 8:04 AM
    There is always the sawzall. I have always found discount tire to give a better price on tire and wheel packages than even over what I can find online, and that is before I tell them what I have found the deal for elsewhere. You might call them with the tire and wheel that you want and see what price they give you installed without warranty. Remember free tire wheel rotation and balance for the life of their tires.
  9. Mar 27, 2017 at 8:05 AM
    Goodfellas
    2006 commander
    I like the way you think haha. Ok yeah im going to go through them i have a rim in mind and will contact them, thanks alot!
  10. Mar 27, 2017 at 10:38 AM
    Post pictures when you get them on:)
  11. Apr 5, 2017 at 7:34 PM
    Goodfellas
    2006 commander
    Hey guys im back, been a bit but shes finally all hooked up i went with Hankook Dynapro MTs 265 60r18 HAS to be the biggest MT that will fit the commander with no lift because sheesh are they close but no touching whatsoever i love em..it turned out pretty good..i will get a lift soon though!
  12. Apr 5, 2017 at 7:35 PM
    Goodfellas
    2006 commander
  13. Apr 5, 2017 at 7:36 PM
    Pics!!!:cookiemonster:
  14. Apr 5, 2017 at 7:36 PM
    Nice!!
  15. Apr 5, 2017 at 7:37 PM
    Goodfellas
    2006 commander
  16. Apr 5, 2017 at 7:37 PM
    Goodfellas
    2006 commander
  17. Apr 5, 2017 at 7:39 PM
    Goodfellas
    2006 commander
    Yeah it came out pretty good the stock offset is like a +20 the wheels have a 12mm offset they stick out 8mm and look great good ride looks nice, im glad it all worked out
  18. Apr 5, 2017 at 7:40 PM
    Goodfellas
    2006 commander
  19. Apr 5, 2017 at 8:18 PM
    That looks very good. I love the hankook mts. They are all I will run on my trucks. Never had any problems and I'm on my 5th set. I tried one set of ATs and they had a high pitched wine on concrete that I didn't like so I went back to the MTs.
  20. Apr 15, 2017 at 7:50 PM
    Goodfellas
    2006 commander
    Im back with another question. I want to lift it and heard that anything over 2 2 1/2 in. Will screw up the drive, any suggestions? Thanks.
