2007 Grand Cherokee Laredo turn signal issue
Discussion in 'Grand Cherokee' started by EWitmer, Apr 16, 2019.
  1. Apr 16, 2019 at 2:51 PM
    EWitmer
    EWitmer [OP] New Member
    2007 Jeep Grand Cherokee Laredo
    I have a 2007 3.7L V6 Grand Cherokee Laredo and the turn signals have stopped working. I have already replaced the turn signal column, the hazards still work as normal. I have scoured the interwebs looking for a solution with no relevant results. Every solution I can find does not apply to my model, do I need to take it to a mechanic or is this something I can fix on my own.
  2. Apr 18, 2019 at 10:42 AM
    the system runs thru TIPM and front module - checking bulbs is most you can do without a scanner to ck 'B' series codes and a wiring diagram.
    Hopefully you have not modified the bulbs - wrong type ie LED's.
