2008 Jeep Grand Cherokee overheating
Discussion in 'Grand Cherokee' started by TaeeWhite, Nov 13, 2019.
  1. Nov 13, 2019 at 11:03 AM
    TaeeWhite
    TaeeWhite [OP] Member
    Davonte
    2008 Jeep Grand Cherokee Laredo
    Soon to replace the transfer case
    My vehicle is starting to over heat and blowing out smoke through the grill. Was thinking about replacing the radiator itself and as well as my upper and lower radiator holes to start with. Anyone have any similar situation like this ?
  2. Nov 13, 2019 at 11:16 AM
    Vehicles over heat for various reasons. Since the plan is to replace parts don't forget the thermostat and inspect the water pump for leaks or noise and fans for proper function.
  3. Nov 13, 2019 at 11:31 AM
    TaeeWhite
    Davonte
    My fan doesn’t turn on by itself either.
  4. Nov 13, 2019 at 2:20 PM
    save money, have a professional assist you with the diagnostics repairs and maintenance of your jeep.
  5. Nov 24, 2019 at 9:56 PM
    TaeeWhite
    Davonte
    I replaced my radiator and thermostat and every is good so far . Will be replacing my upper radiator holes and putting on a new water pump
  6. Nov 25, 2019 at 5:49 AM
    If everything is running good so far I wouldn't mess with the water pump or hoses unless it really needs replacing.
  7. Nov 25, 2019 at 5:54 AM
    TaeeWhite
    Davonte
    My upper holes definitely need changed and ok thanks
