2009 jeep liberty sport hesitating uphill on reverse
Discussion in 'General Jeep Discussion' started by Preyes57, May 26, 2019.
can be the egr malfunction
  1. maybe EGR valve damaged
    1 vote(s)
    100.0%
  2. fuel tank dirty
    0 vote(s)
    0.0%
  1. May 26, 2019 at 5:24 PM
    Preyes57
    Preyes57 [OP] Member
    2019 jeep liberty Sport
    when i backup on reverse uphill my hesitates big time., I already replaced fuel pump, spark plugs, plugs wires,coils and injector cleaned.,Any suggestion,please
  2. May 26, 2019 at 7:28 PM
    Is the engine hesitating, or is the engine running fine, but feels like its slipping in gear?
  3. May 27, 2019 at 4:47 AM
    See your local friendly jeep dealer - this is a 2019 model year surely a warranty issue.
  4. May 27, 2019 at 5:06 AM
    OK after posting above I see conflicting information...
    Is this a 2019, or a 2009?
    figuring the issue is likely a older jeep, the 2009 - a guess.
    which engine and transmission.
    As mentioned does this feel like a slipping trans?
    Have you -
    checked trans fluid?
    Checked for a diagnostic code, I suggest a FREE scan at one of the auto part stores,
    >>FYI scan even if CEL is not on, Trans codes do not always set CEL to on.
    Add any maintenance history- recent repairs, trans service history, modifications etc.
  5. May 27, 2019 at 5:15 AM
    Does this happen moving forward uphill?
    Jeep discontinued the Liberty in 2012 so update your avatar
  6. May 28, 2019 at 6:14 AM
    Preyes57
    only uphill,on reverse ,is 2009 liberty sport.
  7. May 28, 2019 at 7:59 AM
    X2
    Have you -
  8. May 28, 2019 at 8:22 AM
    @Awrench ... professional scanner should be able to read general trans codes but for specific error a visit to the dealer was required for specific trans error code for my honda.
  9. May 28, 2019 at 10:12 AM
    Preyes57
    I checked trans fluid is full.,might be tranny going out.
