2012 JK Sahara - engine light + Traction control = low power?? intermittent
Discussion in 'Wrangler JK (2007-2017)' started by ClimbandRide, Mar 25, 2019.
  1. Mar 25, 2019 at 4:32 AM
    ClimbandRide
    ClimbandRide [OP] New Member
    2012 Sahara JK
    New to the forum here and have seen some older posts but no resolutions
    Any updates on this issue with engine light coming on followed shortly by traction control light and then engine running with reduced power/not shifting down at highway speeds? Symptom has happened in full sequence twice over several months and in addition have had intermittent engine light that clears with in a day or so.
    Both times at highway speeds for loss of power / shifting issues after engine light and traction control light come on
    Only mods are 295/70 R17 NItto TG2 with Fuel Beast rims. And Bilstein Shock replacements - 4-5 months prior to these issues.
    Thanks!
  2. Mar 25, 2019 at 5:33 AM
    welcome hope we can help -
    The CEL was on SO there is a code stored. Suggestion 1 would be a scan. FREE at auto part stores. SCAN even if CEL is now off.
    Mention ANY engine modifications and aftermarket parts.
    JKBob 25, ClimbandRide[OP] and aggrex like this.
  3. Mar 25, 2019 at 2:52 PM
    ClimbandRide
    2012 Sahara JK
    Thanks - i had heard codes were not stored so this is helpful!
  4. Mar 25, 2019 at 3:33 PM
    Welcome @ClimbandRide ! Get the codes read at auto parts stores like Advance Auto and post them here. The codes can be erased but will reappear as the problem(s) need to be addressed.
  5. Mar 25, 2019 at 6:49 PM
  6. Mar 27, 2019 at 7:40 AM
    ClimbandRide
    2012 Sahara JK
    Friend had code reader. Two active codes
    #1 P0600
    #2 P0369
    Quick google search sounds like "Camshaft Position Sensor 2 Circuit Intermittent Bank 1"
    Any one ave any experience with this and best way to solve?
  7. Mar 27, 2019 at 8:25 AM
    this is a BANK 1 CMP sensor issue, bank 1 is passenger side.
    Lets start easy simple, this is a VVT engine SO engine oil is critical, correct weight, filter and must change it often!
    tell us the oil, filter change routine, to be safe add 1 bottle 'risolone' an oil detergent just incase any sludge varnish.
    Check elec connector on CMP sensor passenger head top of valve cover rear, tight corrosion free.
    How are you with a DVOM and a wiring diagram if its not the simple easy?
    CMP is item #5 in attachment
    • CMP.pdf
      File size:
      79.7 KB
      5
