2way radio mount
Discussion in 'Cherokee' started by 2oldjeeps, May 10, 2017.
  1. May 10, 2017 at 11:15 AM
    2oldjeeps
    2oldjeeps [OP] Well-Known Member
    98 and 2000 xj's 99wj
    this mount puts the radio above the shifter,out of the way of pass and angled toward driver to line up without tilting your head. not pretty but functional. its a 3 point mount, no wiggle,in a hummer and jeep seat bolts look the same.
    Bob and chris4x4 like this.
  2. May 11, 2017 at 8:37 AM
    Gets the job done. Where did you grab the parts from?
  3. May 11, 2017 at 8:56 AM
    2oldjeeps
    believe it or not! two of the angled parts "showed up" in my barn full of junk! the flat straight piece was a cross tie support from a utility pole and the round pipe from a junk satellite dish.. but all could be cut,bent from one inchx 1/4 flat iron from the hdwe store/lowes,etc. drill,use 14/20 bolts.
    its a fab job diu. lots of imagination, necessity mother of design huh..
    wires go direct to batt,30 amp fuse
  4. May 19, 2017 at 11:26 PM
    cjsdad
    cjsdad Member
    Dailey
    albuquerque, NM
    1998 Cherokee Laredo
    No mods yet...
    Dood, I really hope that isn't an open-backed power distribution panel that I have highlighted. If it is, that is a smoke test waiting to happen! At least tape some cardboard or plastic over the bare wiring to protect it. One good leg-bounce against that while rock crawling or even traveling a bumpy road and you will have at least a burned fuse, at most a fire. Please cover that up.
  5. May 20, 2017 at 9:39 AM
    2oldjeeps
    ha! its amazing what worries others that is never a problem for me you can use the mechanical idea and run power as you wish. the post is for info only, you need not worry for me!. ive used a dozen of those fuse panels ,with a master fuse,zero trbl. enjoy.
  6. May 21, 2017 at 9:33 AM
    cjsdad
    cjsdad Member
    Dailey
    albuquerque, NM
    No mods yet...
    It's all good. I was a stereo installer for 15 years so automotive wiring is a hot topic for me. In the stereo industry it doesn't always matter how good it sounds, it HAS TO look good. In level of priority of a stereo installer, Looks, safety, performance. I won't bust your balls for anything you do, but I will point out ways to make improvements if I see them. I will also point out that you have a very solid mount for the radio. Excellent job on that. :cheers:
  7. May 21, 2017 at 2:07 PM
    2oldjeeps
    years ago i gave up pretty for functional and rugged. im usually the only one who sees my stuff,,never melted wires!!
    oh i did paint that metal though!
