3.8L v6 oil filter angle mount
Discussion in 'General Jeep Discussion' started by dancar, Jun 21, 2019.
  1. Jun 21, 2019 at 7:30 AM
    dancar
    dancar [OP] Member
    07WranglerX
    Stock
    Ok the title isnt clear but what to call it..? Id like an oil filter bracket/boss/mount to change the filter angle from horizontal to more vertical on my '07 ck to help prevent dry startup which over time leads to damaged engine and oiling issues on these engines around 180k +- miles.
    Anyone know where to find such a mount? Who makes them?
    I know the filters are supposed to have ck valving but let it sit awhile and you will hear dry start rattle.
  2. Jun 21, 2019 at 7:44 AM
    Jeep Cherokee XJs used an oil filter adapter to change the angle and orientation of the filter.
    I do not see anything like that for the 3.8 but do find oil filter relocation kits.
    Billy1234 likes this.
  3. Jun 21, 2019 at 9:00 PM
    I'm not convinced relocating the oil filter will produce the benefit you're looking for. Perhaps switch to a synthetic oil. Summit doesn't list a relocation kit for the '07 JK and most of the reviews stated either leaks or ease of oil filter changes. For example on a 94K Toyota I switched to synthetic oil which flows better on cold winter starts and doesn't leak or burn at 170K with a horizontal oil filter placement.
  4. Jun 22, 2019 at 6:11 AM
    dancar
    dancar [OP] Member
    07WranglerX
    Stock
    Engine and Jeep at 82K, using a full synthetic. At times it can be my daily driver but not work transportation. As stated before, after sitting unused a few days it rattles on startup and many of these engines have a 150-180k mile oiling history (non oem service reports - of course). Just being preemptive and if I can, why not?
    Does anyone have mechanical drawings of the oil boss on the block? I could fab my own mount.
  5. Jun 22, 2019 at 6:12 AM
    dancar
    dancar [OP] Member
    07WranglerX
    Stock
    And thanks for all your input.
  6. Jun 22, 2019 at 6:40 AM
    dancar
    dancar [OP] Member
    07WranglerX
    Stock
    And oops it's actually a "jk" isnt it. My bad.
  7. Jun 22, 2019 at 9:16 AM
    Billy1234
    Billy1234 Well-Known Member
    William
    1997 XJ 2 door
    None yet
    I need that for my xj you got a link?
  8. Jun 23, 2019 at 11:18 AM
    dancar
    dancar [OP] Member
    07WranglerX
    Stock
  9. Jun 23, 2019 at 2:03 PM
    The adapter or relocation kit?
    Billy1234[QUOTED] likes this.
  10. Jun 23, 2019 at 2:32 PM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Whatever one will stop the tick on start up on my xj I get a tick when I start it or if that's just something it does
  11. Jun 24, 2019 at 5:46 AM
    I'm not sure that that is related to the oil filters orientation.
