3" lift ideas for 2000 TJ
Discussion in 'Wrangler TJ (1996-2006)' started by Warrenb, Feb 16, 2018.
  1. Feb 16, 2018 at 7:56 PM
    Warrenb
    Warrenb [OP] New Member
    Black 2000 TJ
    wheels, tires, exhaust
    in need of some ideas for a 3 inch lift for my 2000 Tj.
  2. Feb 16, 2018 at 9:13 PM
    JKBob 25, Bob and chris4x4 like this.
  3. Feb 17, 2018 at 4:01 AM
    mudbug85603
    mudbug85603 Active Member
    Jim
    Upstate SC
    For a decent budget minded lift look at Zone Offroad their 4.25" combo lift comes highly recommended by many. For a 3" lift just don't use the 1.25" body lift blocks. if you see the need in the future for more tire clearance then you could add the blocks. http://zoneoffroad.com/zone-offroad-products-4.25in-suspension-lift-kit-jeep-wrangler/j25-j26
    They also offer a 3" lift http://zoneoffroad.com/zone-offroad-products-3in-suspension-lift-kit-jeep-wrangler/j2-j3
    Be aware that you could and probably will have driveline vibrations with any lift at 2" or above. You may also consider buying adjustable control arms.
    JKBob 25 and Bob like this.
  4. Feb 17, 2018 at 3:40 PM
    UrbanCowboy
    UrbanCowboy Well-Known Member
    Sean
    Scottsdale AZ
    2002 Wrangler... Hulk
    On my old 2000 Sahara I ran a 2” Procomp lift with Bilstein 5100’s on stock wheels. I believe my tires were 32x10.5. It was a really solid lift on the lower end of the price scale. Currently I run a Rubicon Express 3.5” with 1” body lift and Fox 2.0 shocks with remote reservoirs. More expensive, but with cut fenders, I’m running 37’s. I have absolutely no complaints about the set up. It’s awesome.
    I’ve also heard nothing but good things about Rock Krawler and Old Man Emu. If I were starting new, I’d probably go Rock Krawler.
    With a 3” you’ll probably want to do SYE and some other things to prevent driveline shake. This is part of the reason the 2” is a great value. The springs and shocks aren’t much cheaper than a 3-4” lift, but you don’t need to do anything else to the Jeep to run a 2”.
  5. Feb 17, 2018 at 8:03 PM
    Welcome to the forum.
    Great advice posted up top. Post pics....we like Jeep Porn pics. Lolll.
    My DD is a 2016 JK with a 2" lift and 35s. Not a TJ. But, with the flat fender flares. My lift looks like it's a 4". If yoir looking for a simple basic lift. As @UrbanCowboy posted is your best bet. But all info above is also do able. Post those pics.
