3 speed vs 4 speed
Discussion in 'CJ' started by pastor scott, Oct 2, 2018.
  1. Oct 2, 2018 at 2:37 PM
    pastor scott
    scott
    1978 CJ 7
    none right now
    So I have this 78 CJ 7. 3 speed manual. Any good ?? It works fine
    Heard the 4 speed has a granny low. What do you think and how is the swap and is it worth it .
    This will be off road only build.
    Thanks
    Ps Scott
  2. Oct 2, 2018 at 5:48 PM
  3. Oct 3, 2018 at 6:32 AM
    Agree with Prerunner. You most likely have the T150. It is bullet proof, but very lacking in the low gear department. As prerunner says Go hear for all the tranny information and tranny swap info that you will need. https://www.novak-adapt.com/
  4. Oct 4, 2018 at 8:23 AM
    pastor scott
    scott
    1978 CJ 7
    none right now
