3550 fluid change
Discussion in 'Wrangler TJ (1996-2006)' started by Kerryike, Nov 25, 2017.
  1. Nov 26, 2017 at 9:43 AM
    #21
    Kerryike
    Kerryike [OP] Member
    Kerry
    2002 Wrangler TJ
    Thanks so much for your diligence, Chris. At least I know what I have now...even though I'm not too happy about it. I'm not sure what these wires would be, but not only would someone be unable to put a socket on it, the wires would twist when backing out with a wrench. No matter...I'll probably save my expensive Synchromax for a tranny upgrade. My future plans include an engine swap. Not go na do that with an AX5.
  2. Nov 26, 2017 at 10:05 AM
    #22
    Does this look like it could be familiar?
  3. Nov 26, 2017 at 10:07 AM
    #23
    This is the fill plug, in the yellow circle.
    ooops
  4. Nov 26, 2017 at 10:07 AM
    #24
    crap....hand on
  5. Nov 26, 2017 at 10:07 AM
    #25
  6. Nov 26, 2017 at 10:08 AM
    #26
    I'm determined to see this thru!! :)
  7. Nov 26, 2017 at 10:11 AM
    #27
    I think its a 15/16" size, from what I am reading
  8. Nov 26, 2017 at 10:15 AM
    #28
    More info?
    #28
  9. Nov 26, 2017 at 10:17 AM
    #29
    This is it removed.
  10. Nov 26, 2017 at 10:27 AM
    #30
    I have to run out with the Wife, so let me know if any of this helps.
  11. Nov 26, 2017 at 11:20 AM
    #31
    Kerryike
    Kerry
    2002 Wrangler TJ
    Thanks. That is what I was thinking was the fill plug. I may change it anyway, as I don't know how soon I may be changing powerplants. Its a bit disappointing that someone transferred that tranny in my 2002.
  12. Nov 26, 2017 at 11:57 AM
    #32
    as long as its working fine, I wouldn't worry about it. It might not be the favorite for some, but its not bad.
  13. Nov 26, 2017 at 6:57 PM
    #33
    Dang! Great job Chris!
  14. Nov 26, 2017 at 7:10 PM
    #34
    I guess you were out wheeling, and I had to step up. Kinda wish you hadn't set the bar so high!! :)
    aggrex, OFFGRID[QUOTED] and JKBob 25 like this.
  15. Nov 28, 2017 at 7:06 PM
    #35
    Insert "clapping hands" for @chris4x4. You da man dude. Awesome work. :thumbsup:
    aggrex, OFFGRID and chris4x4[QUOTED] like this.
