4.0L pan to pick up clearance issue
Discussion in 'General Jeep Discussion' started by jeepcreep, Apr 17, 2020.
  1. Apr 17, 2020 at 8:10 PM
    jeepcreep
    jeepcreep [OP] New Member
    Kat
    1998 Tj
    I am new to the forum so hello to all.
    I am building a stocker motor for my lad’s 97 tj.
    All set to button up the bottom end but here is my issue.
    No stock pan or oil pump/pick up to reference.
    Installing a Moroso kick out oil pan#27862 and a Melling oil pump and Melling pick#242s (both Noted as stock replacement pieces)
    My pre oil pan gasket clearances are as follows;
    Pan to pickup shield is 0.262
    Pan to pickup screen is 0.607
    Bottom of pan is level, pick up is not bent or deformed.
    Moroso tech states their pan works with stock oil pump/pickup.
    Melling tech states their oil pump/pickup is made to stock specs.
    I cannot believe there is not an off the shelf solution for this application?
    Anyone run into this problem?
    Did you have to fab a pick up screen and housing?
    Any help would be appreciated.
    My goal is to have post gasket pan to pick up screen clearance of 0.250 to 0.367
    Thanks,
    Pat
  2. Apr 18, 2020 at 2:50 PM
    If the manufacturer says it will work then it might be a good bet that it will, especially if you have no other option.
  3. Apr 19, 2020 at 12:46 AM
    jeepcreep
    Kat
    1998 Tj
    Don,
    I get that but a stock clearance is 0.250 to 0.500. My setup yielding over 0.600 pre gasket would be scary on flat ground let alone on a trail.
    Just to easy to my way of thinking to suck some air.
    Worst case I will fab a pick up.
    Thanks for chiming in though.
    Wish me kuck.
