4.2 Wrangler Intake Manifold
Discussion in 'Wrangler YJ (1986-1995)' started by Loaki, Mar 7, 2020.
  1. Mar 7, 2020 at 11:09 AM
    Loaki
    Loaki [OP] New Member
    Kevin
    1988 Wrangler YJ
    4” Lift
    I am new to Jeeps and finally pulled my 88 out of the garage. It is at the shop for an engine rebuild. Had water in the oil pan. Got the new engine in and they are working to get her back in running condition. One of the issues my mechanic found as he was cleaning the intake manifold was a hole in it. He has been look for a replacement but it looks like the engine was only used from 87-90. So far he is running out of luck. I have been surfing Google as well and no luck on finding a replacement.
    Any ideas on a new intake Manifold for a 4.2 I6? Any help is appreciated. Thanks!
    Dallas Texas here.
  2. Mar 7, 2020 at 12:25 PM
    can the hole be patched up? Its only cast aluminum.
  3. Mar 7, 2020 at 12:33 PM
    Loaki
    Kevin
    1988 Wrangler YJ
    4” Lift
    He says he can weld it. But was opting for a replacement before he did, his concern was that it was due to coercion
  4. Mar 7, 2020 at 1:23 PM
  5. Mar 7, 2020 at 1:25 PM
    Loaki
    Kevin
    1988 Wrangler YJ
    4” Lift
    Thanks for the link, def going to check them out.
  6. Mar 7, 2020 at 1:32 PM
    If the hole is small can it be tapped for a bolt?
