4:88 gears vs 4:1 Tcase
Discussion in 'Wrangler JK (2007-2017)' started by HardHat420, Mar 14, 2018.
  1. Mar 14, 2018 at 8:12 AM
    HardHat420
    14 jku sport
    Wondering what you guys think about upgrading gears vs tcase low ratio?
    Upgrading either will cost me about the same but I have a Dana 30 up front and will be replacing that later with a 44 or 60 and don't want to have to buy gears twice.
    Upgrading the tcase would be a one time deal regardless of how many times I change axles.
    Currently have 3:73, 35s, automatic.
    I like crawling as slowly as possible but also like using low gear for mud and sand.
    Thanks any thoughts are helpful.
  2. Mar 14, 2018 at 8:43 AM
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    I vote t case. I'm in the same boat need a rehear but want to switch axles later and don't want to do gears twice.
  3. Mar 14, 2018 at 8:59 AM
    To effectively crawl low-speed go for the 4:1 TC. IMO you can wait a bit on the gears until you're flush with $$$ or sell a few parts (jeep) :)
  4. Mar 14, 2018 at 7:30 PM
    HardHat420
    14 jku sport
    Thanks guys.
    With your help I've decided on the tcase.
  5. Mar 15, 2018 at 11:36 AM
    HardHat420
    14 jku sport
    So after talkin with a guy who knows a thing or 2, another option is a rubicrawler for our current setup.
    It would double our current 2.72:1 for crawling.
    Have you looked into that by any chance?
  6. Mar 15, 2018 at 11:40 AM
    I would prefer a doubler so that you have more options. You may not always need 4.0:1 and in a JKU you have a little more wheelbase to work with.
  7. Mar 15, 2018 at 12:10 PM
    HardHat420
    14 jku sport
    A double?
    Do tell more.
    That sounds even better since we do sand race and mud bog as well as technical crawling.
  8. Mar 15, 2018 at 12:23 PM
    Rc Jeep
    Ryan
    '16 Rubicon
    I'm in a rubicon so I have the 4:1 t case. Even with 4:10 gears on 37s 1st is almost unuasuable too much torque. On the other side 2wheel and 4 wheel hi are incredibly under powered
  9. Mar 15, 2018 at 12:25 PM
    A Rubicrawler is a doubler.
    Originally people would adapt the low range portion of another transfer case to their existing transfer case (sometimes also called a dual transfer case), now companies make add on gear boxes for the same effect.
    Not sure what doubler gear ratios are available but I think a doubler with 4.0:1 gearing would be good. You would have the option of just engaging 4H (1:1), just engaging 4L (2.72:1), leaving it in 4H and engaging the doubler (4.0:1) or 4L and doubler (10.88:1).
    1st gear, 4L, doubler, with stock gears and you are looking at a crawl ratio of about 109:1
    Though that may be too much.... :jeep:
    A 2.72:1 doubler would work good too, about 74:1 crawl ratio.
    Crawl ratio = 1st gear ratio x low range ratio x axle gear ratio.
  10. Mar 15, 2018 at 12:47 PM
    HardHat420
    14 jku sport
    Are there doublers besides rubicrawler?
    I called the manufacturer and they don't make the rubicrawler for >2012 jk.
    Thanks! Was just lookin for that formula!
  11. Mar 15, 2018 at 12:58 PM
    HardHat420
    14 jku sport
    Oh ok. How soon you plan on upgrading the 44s?
    I would totally gear a 44. The only reason I don't want to gear my axles now is that I have the Dana 30 and will be replacing it sooner than later.
  12. Mar 15, 2018 at 1:00 PM
    Not sure about the JKs, the next option may be to look at an Atlas or Stak transfer case but they are $$$$.
  13. Mar 15, 2018 at 1:05 PM
    In the end..... you may just be better off to re-gear. :turtleride:
  14. Mar 15, 2018 at 2:37 PM
    Rc Jeep
    Ryan
    '16 Rubicon
    When I have $12k to blow... I want to run 40s
  15. Mar 15, 2018 at 5:19 PM
    HardHat420
    14 jku sport
    We are on the same boat then.
    These damn jeeps take all of our money.
  16. Mar 15, 2018 at 5:27 PM
    HardHat420
    14 jku sport
    This is the conclusion I'm coming to as well, sadly.
    I just installed the lockers
    I think ill leave it the way it is and learn to crawl with a high ratio.
    I would like to gear it but I would hate to do that PLUS the locker and then the axle breaks right away.
    Only reason I locked the 30 was because I got a good deal on the ox, $1000 installed.
    Sounds like you might have the 44s for at least a while. I would totally gear it especially with 37s. Throw some 5:13s in it.
    Have you gotten a tuner? It helps a lot.
  17. Apr 5, 2018 at 11:00 AM
    HardHat420
    14 jku sport
    How would I know what my '1st gear ratio' is?
  18. Apr 5, 2018 at 11:14 AM
    What transmission do you have?
  19. Apr 5, 2018 at 4:49 PM
    HardHat420
    14 jku sport
    Did a quick search and found I may have a Mercedes Benz w5a580. I can call the dealership tomorrow and find out for sure.
  20. Apr 5, 2018 at 8:34 PM
    If it is it should have a 3.59 first gear.
