Slight vibration with 4 inch lift
Discussion in 'Wrangler TJ (1996-2006)' started by jeepfam, Jan 19, 2019.
  1. Jan 19, 2019 at 3:36 PM
    jeepfam
    jeepfam [OP] New Member
    Terry
    '72 CJ5
    SOA is about it with 35's
    Put a 4 in lift on son's TJ, we have a slight vibration taking off then it disappears, has anyone put 4inch lift and had problems, driveshaft isn't in a bind
  2. Jan 20, 2019 at 6:03 PM
    This is normal for a 4in lift. The cheap way to get rid of it is to install a transfer case drop kit. The correct way to do it is to install a SYE kit.
