50" Auxbeam wiring (without roof holes!)
Discussion in 'Cherokee' started by Daikaiju_Sadism, Apr 26, 2018.
  1. Apr 26, 2018 at 2:14 PM
    Daikaiju_Sadism
    Daikaiju_Sadism [OP] New Member
    Ohio
    2001 Cherokee Limited
    3" Rough Country Lift, 50" Curved Auxbeam light bar, Chrome package light housings
    Hey all, for anyone looking to save their XJs from holes in the roof, I've decided to post a thread-tutorial for wiring a 50" curved Auxbeam light bar into an 01 XJ through the interior paneling.
    The most you'll have to sacrifice is a notch off the top panel and a small hole in the driver's side weather stripping to allow the wire from the light bar inside the paneling and to squeeze down the windshield pillars. The wiring kit that came with the Auxbeam light bar came in one piece with switch connected. Wire both sides separately. i.e the wire that runs from the light bar (I will refer to this as the Primary wire), and the other half of the harness wired from the battery and through the firewall into the cabin ( I will refer to as the secondary wire).
    With the light bar previously mounted in place, the primary wire (From the light bar) will travel inside and down the Windshield pillar paneling to connect with the secondary wire (from the firewall that leads to the relay and the battery).
    Likewise once the bottom half of the harness (secondary wire) has been hooked to the battery, routed around the engine compartment, and pushed through the firewall...
    and inside the cabin...
    The secondary wire will be pushed into the panel just behind the hood latch, you'll likely want to unscrew the side paneling a little to avoid cracking it when maneuvering the wire inside.
    The secondary wire will be routed up the paneling from the hood latch, into the slim paneling that leads up to the window pillars.
    And in the middle we meet with our primary and secondary wire ready to crimp or solder together and tuck back into the paneling
    Afterwards test the friction on the wire received from the door upon closing. Ensure the wire is securely molded against the frame of the door if resistance is noted.
    After wiring is complete your light bar harness should have a (nearly) seamless look. Hey, no roof holes!
    I know this style of wiring must be obvious to some, but I thought I'd throw this out on the forums for good measure. Why not.
  2. Apr 26, 2018 at 3:11 PM
    Good info! Welcome aboard!
  3. Apr 26, 2018 at 3:29 PM
    Welcome! Nice write up with pics.
