83 CJ cranks but won't start
Discussion in 'CJ' started by Minidiehl, Nov 26, 2016.
  1. Nov 26, 2016 at 3:26 PM
    Minidiehl
    Minidiehl [OP] New Member
    Trevor
    1983 cj7
    None
    I have a 1983 cj7 I just purchased. It does not run. When you turn the key it has a shot of spark and then nothing, still cranks but no more spark. I have replaced all electronics that are on the jeep. I have no idea what to do
  2. Nov 28, 2016 at 8:50 AM
    Fuel, Spark, and Air are needed to run. Provided you have already made sure that you are getting fuel and air to carburetor. I had all kinds of problems with the ford electronics on my CJ engine. Perform a "Nutter Bypass" (Remove your computer and Ignition control module) replace the ford Ignition coil and distributor with a Chevy HEI distributor (I bought mine new on Ebay with the Jeep cam shaft gear for under $100). This fixed all of my engine electrical issues.
