83 CJ7 won't run
Discussion in 'CJ' started by 1rollinred, Dec 14, 2021.
  1. Dec 14, 2021 at 7:28 AM
    1rollinred
    1rollinred [OP] New Member
    PNW
    Fired it up one day, started as usual. Few minutes later reached in and kicked it down. It dies. Will not re-start. Starting fluid, nothing.
    Brought into my shop and have now replaced: cap, rotor, coil, condenser, plugs, ignition pulse generator, ignition control unit and cleaned the grounds well.
    I can get it to fire now and will start but only runs a little and very poorly. It will only fire as I release the key. It never did this before.
    Yes, it is getting fuel.
    Thoughts?
  2. Dec 15, 2021 at 10:20 PM
    1rollinred
    PNW
    I guess there isn't anybody on this forum. Better luck with the folks over at jeepforum.com
    Got some help over there.
  3. Dec 16, 2021 at 5:52 PM
    Black jeep of family
    Black jeep of family New Member
    neil
    1984 cj7
    stock
    fuel filter??? had that similar and was dirty filter from pick up sock that rotted in gas tank
  4. Dec 16, 2021 at 11:16 PM
    1rollinred
    PNW
    Have not done that, will give that a go, thanks.
    Initially it was not getting any fire. Now it will run but not enough to drive so fuel is my next event!
