87 YJ Build
Discussion in 'Wrangler YJ Builds (1986-1995)' started by Groundfault, Jul 5, 2021.
  1. Jul 5, 2021 at 1:21 AM
    Groundfault
    Groundfault [OP] Well-Known Member
    Tim
    87 Wrangler, kind of...
    A few photos of the never ending project. Have the gas tank out right now to replace skid. I'm planning on driving it over to Vigilante 4x4 in Prescott Valley this week to weld an Artec truss to the Dana 60 front and weld up the 1 1/2" tie rod and drag link. The tie rod still needs to be moved up to the high steer arms. First time I've taken it to someone, but I don't have the equipment or confidence to weld a truss. Still have quite a few adds that I want to do. I have a Barnes 3" drop skid plate on the way along with new door seals. Want to do a high driveline e-brake on the back of the NP205 (rears are converted to disc and I've removed the cable and e-brake pedal), antirock sway bar, fab 4 point harness mounts for back seat, Hydro assist, truss the 14 bolt rear?
  2. Jul 5, 2021 at 6:15 AM
    The YJ looks awesome. Best "SQUARES" I've ever seen. Great Jeep build!
  3. Jul 14, 2022 at 3:38 PM
    gear head girl
    gear head girl New Member
    turbo girl
    93 jeep y.j 35's
    3.5 lift 1 1/2 shackles rear axle extended 1.5 inches 35x12.50 goodyear wrangler mudz limited slip diffs
    that jeep is sick .i like the squares because nobody else does . nice swag fosho
