91 Cherokee 4x4 slip yoke help
Discussion in 'Cherokee' started by Cherro91blu, Dec 9, 2017.
  1. Dec 9, 2017 at 8:57 AM
    Cherro91blu
    Cherro91blu [OP] New Member
    John
    1991 blue cherokee 4x4
    5 inch lift, 31.5 mudders
    I bought a 91 Cherokee 424 trans with a 5 inch lift and 31.5 mudders. Basically I can see 3/4inch of yoke coming out of the transfer case. And have been informed that if I break hard enough that the slip yoke will simply come off. Which one can imagine the chaos with a drive line slamming around everything until stopped. Please help!
  2. Dec 9, 2017 at 3:02 PM
    Welcome!
    I would think that you would need to install the correct length drive shaft.
  3. Dec 9, 2017 at 5:56 PM
    With that much lift you really should have a slip yoke eliminator. Pro-comp and rugged ridge are both made by advanced adapters. of the three get whatever is cheapest. then you will need Tom Woods drive shafts to make you a new one.
  4. Dec 9, 2017 at 6:33 PM
    Welcome to the forum Cherro91blu.
    You came to the right place. @OFFGRID is probably our best driveline guy. He knows his shit.
  5. Dec 10, 2017 at 10:43 AM
    Cherro91blu
    John
    Thank you for your help. I knew about the slip yoke eliminator, but the transfer case I have is a 424 and not the typical 231. I couldn't even find a kit until I had key words of advanced adapters... Thank you for that! Im starting to think that this is not going to be a cheap fix no matter how I look at it.
  6. Dec 10, 2017 at 7:21 PM
    I think you mean the NV242 Tcase. I believe they are so similar that the SYE kits are the same kit for both. Contact Advanced adapters or Tom woods drive shafts (They also do SYE kits) for more information. Check this link out from Tom Woods: http://www.4xshaft.com/np231sye.html If you read all the way through to step 1 you will see them reference both the 231 and the 242 regarding this kit.
