93 ZJ 5.2 Heater Core Split Open
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Sep 17, 2019.
  1. Sep 17, 2019 at 12:38 PM
    TinyInkognegroT
    My heater core hose split and is spraying coolant everywhere... Could this be because the hose is maybe old and wore out or its clogged and the pressure caused it to split ?
    https://youtu.be/0NYTmhKeKoY
  2. Sep 17, 2019 at 3:03 PM
    I would go with old, as the material gets older and in a heated compartment it can dry out and crack. There used to be a rule of thumb to replace all hoses after 40 thousand miles. A hose repair kit in the vehicle is a good idea when you are out on the road.
    TinyInkognegroT[OP] and LYFZGOOD like this.
  3. Sep 17, 2019 at 7:50 PM
    Negative to clogged system or pressure. If you are due for a coolant flush you got one started. Replace hose and inspect the condition of any other hose(s)
  4. Sep 18, 2019 at 8:09 AM
    TinyInkognegroT
    I know this probably sounds like a bad idea and probably cheap, but I bought a can of flex Seal to still up the hole it wasn't really that big and water was only coming out of a little hole at the end of the split. Figured I'd spray it down with the rubber spray and use that as a temporary fix until Friday.
  5. Sep 19, 2019 at 7:21 PM
    Splice, plastic connector and pair of small hose clamps
  6. Sep 20, 2019 at 2:01 AM
    learn how to hold the F'in :censored: phone when taking videos...
    kids. :jeepwave:
    PS how was your B'day?
  7. Sep 20, 2019 at 3:49 AM
    TJ4me
    TJ4me Active Member
    2001 Jeep Wrangler Sahara
    I'd flush the system and replace the hose...not repair it.
    Peace of mind down the road...Especially if you take it off the road!
  8. Sep 20, 2019 at 7:15 PM
    I hope this is a joke.
  9. Sep 21, 2019 at 5:17 AM
    TinyInkognegroT
    No, dead-ass and is still running like that. I also wrapped adhesive tape around it lol
