93 ZJ AC
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Oct 26, 2019.
  1. Oct 26, 2019 at 12:34 PM
    TinyInkognegroT
    When I bought this Jeep I was told that the AC clutch or compressor doesn't work. I was told I would have to replace the AC lines and was given ac lines to replace the old ones. I noticed there are some missing pieces and broken/burnt connectors. Can you guys take a look at these pictures and tell me what I'm missing and tell me what kind of problems it can cause ?PHOTO_20191026_141926.jpg PHOTO_20191026_141949.jpg PHOTO_20191026_142108.jpg PHOTO_20191026_142028.jpg
  2. Oct 26, 2019 at 1:55 PM
    1st picture is - low pressure AKA compressor cycling switch.
    2nd see 3rd
    3rd use diagram and it will show the missing line. thinking line #2
    4th not in diagrams listed under #4 line hi pressure cut out switch
  3. Oct 26, 2019 at 2:44 PM
    TinyInkognegroT
    With these pieces missing, can it affect performance?
  4. Oct 26, 2019 at 2:52 PM
    A/C system with unknown history can be problematic for DIY repair. For example A/C lines missing for an extended period of time will require total system flushing. A/C compressor failure for various reasons usually call for condensor, dryer, etc replacement to be done right.
  5. Oct 26, 2019 at 2:55 PM
    WHAT HE said - we can tackle this when your ready expect Ca Ching, I see a vacuum pump and AC gauges in your future - beg, borrowed of stolen.
  6. Oct 26, 2019 at 3:14 PM
    Had success with DIY a/c repair this summer with two important tools: a/c manifold gauges and vacuum pump from HF. Figure on about $120 for both. Picked up the compressor, drier, condensor etc from autozone/advance with 20-25% coupons.
  7. Oct 26, 2019 at 3:48 PM
    You got a vacuum pump AND gauges both for 120$ not 120$ each !! - the pump worked pulled into the high 20's?
  8. Oct 26, 2019 at 6:26 PM
    HF vacuum pump worked great and held the vacuum past the 20s overnight. Got to use them 20% coupons.
  9. Oct 26, 2019 at 7:20 PM
    TinyInkognegroT
    Should I reroute my engine belt without using the AC? If my AC isn't working wouldn't that cause problems to have the belt running running it ?
  10. Oct 26, 2019 at 7:38 PM
    If the a/c clutch is not engaged and the pulley is not making noises I don't see any immediate issue.
