93 ZJ Control Arm Bushing Problem
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Jun 24, 2019.
  1. Jun 24, 2019 at 6:37 PM
    TinyInkognegroT
    IMG_20190624_194904.jpg Knocks when turning the wheel clockwise in reverse
  2. Jun 24, 2019 at 7:02 PM
    Unless I'm buzzed again that sure looks like a bent sway bar end link cracked bushing.
    TinyInkognegroT[OP] and JKBob 25 like this.
  3. Jun 24, 2019 at 7:41 PM
    I am buzzed. And I know that's a bent sway bar, and fubared bushings.
    Quick and cheap fix. Local scrap yard for sway bar. And new bushings. Easy DIY fix.
    Post up your fix dude. Might help another member in the future.
    TinyInkognegroT[OP] and aggrex like this.
  4. Jun 24, 2019 at 8:58 PM
    TinyInkognegroT
    I have a new one with bushings. What kind of problems does this cause ?
    JKBob 25[QUOTED] likes this.
  5. Jun 24, 2019 at 9:00 PM
    TinyInkognegroT
    And yea I sure will post along the way. Helps me if I encounter it again and helps future problems for people.
  6. Jun 25, 2019 at 4:53 AM
    Looseness in sway bar could make some noise, bend the end link, or delay anti sway
  7. Jun 25, 2019 at 5:32 AM
    Not sure that is the cause of the sound.
    Disconnect that side and try the scenario again.
  8. Jun 25, 2019 at 8:20 AM
    TinyInkognegroT
    OK what tools and equipment will I need for this job ? And how do I go about it ?
  9. Jun 25, 2019 at 8:34 AM
    A couple of sockets or wrenches, I don't know the size right off and maybe something to pry with.
    Remove the top bolt (vertical) and the bottom bolt (horizontal) and remove the sway bar link. You may have to pry it out especially with it bent.
    Install the new one and bolt back in.
    If you are unable to get the old one completely out or the new one in for whatever reason, don't be concerned as you can drive without it.
    If you can't get the old one out try to tie it to the swaybar so it is as out of the way as possible and either acquire the cutting tools necessary or have someone assist. A hacksaw would work but would be exhausting, a sawzall or angle grinder with a cutting wheel would be preferable.
  10. Jun 25, 2019 at 10:20 AM
    Off the pic on the bottom of the end link is a bolt requiring either a hex or torx. If the bolt head is very rusty it could strip generating some cussing.
  11. Jun 27, 2019 at 8:11 PM
    Honestly @TinyInkognegroT. I've changed on 3 different Jeeps recently. A XJ, a JK, and a ZJ. And all 3 were different. I'd like to,say do it this way or that way. But cuz the sway bar is a tough streering component. I found the best way. Install the links. This way there's no pressure on the sway bar. Then use your knees, :curls:....or a jack to push the bar up into the main bushing mounts. Although your results may differ......
  12. Jun 30, 2019 at 9:47 AM
    TinyInkognegroT
    Here's better pics of the front end, wheels are turned to passenger side in these pics...IMG_20190629_185412.jpg received_564184104111167.jpg received_1263994367083861.jpg received_670346170058871.jpg received_1874641499304168.jpg
  13. Jun 30, 2019 at 9:49 AM
    TinyInkognegroT
    Drivers side...received_666713870423250.jpg received_663565757440080.jpg received_342009876722532.jpg
