93 ZJ surges after letting off gas
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Jun 24, 2019.
  1. Jun 24, 2019 at 4:19 PM
    TinyInkognegroT
    My Zj acts as if it wants to stop or die when I drive over 45mph. Between 55-45, the rpm jumps, the vechicle jerks and slows a second, then decelerates normally. If I press the gas after that, it accelerates normally. Just acts like that dropping from about 55 and passing 45 as it drops.
  2. Jun 24, 2019 at 6:00 PM
    First guess would be a failing throttle position sensor, but you should soon be getting a check engine light for that.
  3. Jun 24, 2019 at 6:19 PM
    TinyInkognegroT
    I have a check engine light on after several minutes of idling or driving
  4. Jun 24, 2019 at 6:34 PM
    Get the CEL scanned for codes?
  5. Jun 24, 2019 at 7:46 PM
    If your getting engine light. First action should be to get codes. And go from there.
    Post up codes here. Numerous members can help.
