97 Wrangler dies while driving
Discussion in 'Wrangler TJ (1996-2006)' started by HispanicPanic, May 30, 2019.
  1. May 30, 2019 at 2:22 PM
    HispanicPanic
    HispanicPanic [OP] New Member
    Chris
    1997 Wrangler
    2inch lift light bar, Chrome bumper and grill.
    So just got my jeep and now it will die while driving and then take a few minutes before it will start again. It all started with my radio going out, then the turn signals would stop, and now it dies every other day and just cranks amd cranks without ever starting. Wait a few and then it starts again. Any ideas? Maybe ignition switch?
  2. May 30, 2019 at 2:58 PM
    do you want to guess OR try and find the issue -diagnose ?
    First thing we want to do check for codes - scans are FREE at many auto part stores, just copy down all codes they retrieve and post here.
    >> FYI - the CEL can be out and still have codes stored.
    Are there and modifications, recent repairs, add on's, esp powertrain related...
    What is yur comfort level - skilled, a DIYer, or where do I add gas ?
    Bob and HispanicPanic[OP] like this.
  3. May 30, 2019 at 3:30 PM
    Just got the jeep and had no symptoms during the pre-purchase test drive. I think it's possessed.....
  4. May 30, 2019 at 3:48 PM
    HispanicPanic
    Chris
    1997 Wrangler
    I'm a DIYer as best as I can. Ive always had a Chevy till now. Havent had Any codes checked yet. The radio stopped working 2 weeks after I got it and said check wiring, then the blinker wouldn't work... Now it dies as im driving. Quite the progression.
  5. May 30, 2019 at 4:01 PM
    HispanicPanic
    Chris
    1997 Wrangler
    It does have a 2 inch lift also. Not sure if that matters.
  6. May 30, 2019 at 4:12 PM
    lets do the codes check - autozone, advance, orielys do FREE scans as a customer service.
    You did not mention having to jump the battery that is good, Is there a remote starter?
    If yes stop using it and stick with the key start as we try to work thru this.
    I will ask did you check fuses?
  7. May 30, 2019 at 4:33 PM
    HispanicPanic
    Chris
    1997 Wrangler
    No I use the key to start it. I have checked the fuses. The battery is fine also.
  8. May 30, 2019 at 5:36 PM
    Wile you're at those parts stores (autozone, advance, orielys) getting the free scan get the alternator+battery checked too to eliminate some variables.
