98 zj to 94zj ignition coil difference
Discussion in 'Grand Cherokee' started by grg98zj, Feb 1, 2019.
  1. Feb 1, 2019 at 5:26 AM
    grg98zj
    grg98zj [OP] Member
    98 zj
    stock
    can I use a 94zj ignition coil on my 98zj by changing the ignition coil pig tail.
  2. Feb 1, 2019 at 6:05 AM
    I bet it would, as long as you are good with a soldering iron. I have done similar a time or two on my XJs. Keep the old pig tail as you can always go back to it if you need to.
  3. Feb 1, 2019 at 6:23 AM
    grg98zj
    grg98zj [OP] Member
    98 zj
    stock
    I'm using an msd model 8228 coil on it now and it has to have an accel adapter ,because the msd coil uses the 94 type connector.so I think that if the msd coil works on a 92 to 98 models they have to be similar enough from factory to work.
  4. Feb 1, 2019 at 7:30 AM
    rewire, look at part specs all for a 30$ part Give Me A F'in break....
  5. Feb 1, 2019 at 7:42 AM
    grg98zj
    grg98zj [OP] Member
    98 zj
    stock
    sorry Awrench maybe I should of explained a little more my 98 coil harness plug is broke i cant buy a new one.not made any more.i cant find a used one in any pic apart junk yard any where.i do have one from a 94 plus coil.so I need to know if I can swap it and get it running again.sorry if I caused you any F'in pain or discomforts.
    Prerunner1982 likes this.
  6. Feb 1, 2019 at 8:35 AM
    grg98zj
    grg98zj [OP] Member
    98 zj
    stock
    well it seems some one on another forum has located just what I need (standard motor products s2317) .
