99 2.5 wrangler crank no start after washing
Discussion in 'Wrangler TJ (1996-2006)' started by 2.5LiterTrailEater, Sep 15, 2017.
  1. Sep 15, 2017 at 5:07 PM
    2.5LiterTrailEater
    2.5LiterTrailEater [OP] New Member
    Hunter
    1999 Tj 2.5 manual
    My tj performed excellent all Labor Day weekend at Powerline Park (Saint clairsville, Ohio), however after power washing the thick coat of mud off when I got home I ended up with a crank no start. I'm getting no power off the ignition coil and the connection going into the coil is only reading 4.3v. I've checked all of the grounds near the coil and they're all returning 12v. Ecu?? Thanks for any help with this strange issue
  2. Sep 19, 2017 at 7:26 PM
    Did you power wash under the hood too? blow out all electrical connections with compressed air. Make sure everything is dry under the hood. Sounds like something is wet and shorting out.
  3. Sep 19, 2017 at 7:32 PM
    Welcome to the forum Hunter.
    I see you've met OFFGRID. Awesome first member to meet. He knows his shit. Good luck with your issue. Your in good hands.
    Drd88 likes this.
  4. Sep 19, 2017 at 8:41 PM
    Jeepmechanic2003
    Jeepmechanic2003 Member
    David
    Grand cherokee
    Stock for now
    If you have no spark check the crank sensor and see if the connection has water or crosion
