Abs E break traction light all breaks lights coming on
Discussion in 'Wrangler JK (2007-2017)' started by Jdenman, Feb 22, 2018.
  1. Feb 22, 2018 at 9:16 AM
    Jdenman
    Jdenman [OP] New Member
    Josh
    2009 4 door wrangler jk
    3.5 inch lift 35 inch tires 18 inch rims. Iron built bumper and winch.
    Yesterday all the sudden all lights in dash that deal with breaks went on. As soon as I start driving they come on. Drives the same sounds the same and all fluids are good. Any ideas?
  2. Feb 22, 2018 at 9:25 AM
    boondoc89 Well-Known Member
    Do you use your e-brake often? My rig did this one time when I used the e- brake to park on a steep hill. I let the brake free and the brake light on the dash stayed on. I ended up just tightening the brake cable up and ive never seen it again. Maybe it was a fluke but it could be worth a shot
  3. Feb 22, 2018 at 9:29 AM
    Or maybe try loosening it? Could be causing it to be too tight on one of the brake drums setting off a wheel speed sensor:notsure:
  4. Feb 22, 2018 at 9:34 AM
    Jdenman
    Josh
    I don’t use the E brake often but it’s strange because all of those lights come on at once.
  5. Feb 22, 2018 at 9:38 AM
    Might have to go thru and check all of the grounds that are in the circuitry. I see you have an 09 which means it's starting to age and things come loose every now and then. I have an 08 and I'm battling a headlight issue where the low beams are brighter than my high beams.
  6. Feb 22, 2018 at 9:40 AM
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    It's the Infamous Christmas tree. The most common cause for this is a bad positive connection on your battery. Try removing cables cleaning clamp and pole and reattach.
  7. Feb 22, 2018 at 9:49 AM
    Jdenman
    Josh
    Ok I will give that a shot today, I did actually jump my neighbors car before this all happened so that could be it. Thank you for the input I appreciate it!
  8. Feb 22, 2018 at 12:28 PM
    Welcome to the site
  9. Feb 22, 2018 at 1:16 PM
    Jdenman
    Josh
    Thanks chris! So I disconnected the battery cleaned everything up and they same on right away after I started it. If there’s no check engine light on it won’t throw a code so I’m not sure where to take it besides a dealership.
  10. Feb 22, 2018 at 2:05 PM
    I would check under the vehicle and see if any of the speed sensors, or abs lines are damaged, or on plugged.
  11. Feb 22, 2018 at 4:23 PM
    Rc Jeep
    Ryan
    '16 Rubicon
    Chris said it. My next guess was going to be the abs line. I have pinched mine before in my coilovers and got the Christmas tree.
  12. Feb 22, 2018 at 6:55 PM
    Welcome To the forum @Jdenman.
    Sorry, can't help with your issue. But im subbed.
  13. Nov 20, 2018 at 10:46 AM
    Invisiblebully
    Invisiblebully Member
    Chris
    2007 Jeep JKU
    I had a problem with my traction control EBS light as well. I looked for what could be causing the issue online and found a youtube video explaining it my be the wheel sensors. Sure enough, when I took it to the shop it was a bad sensor in back wheel. Give that a try.
  14. Nov 20, 2018 at 12:36 PM
    Pro automotive scanner can identify exactly which wheel speed sensor is defective.
  15. Nov 20, 2018 at 5:23 PM
    If you ever wondered what's inside a wheel speed sensor....
  16. Jan 30, 2019 at 6:03 PM
    Metmancd
    Metmancd New Member
    Chris
    2015 Wrangler unlimited sahara
    2 inch lift 35 BFG’S
    Just replaced wheel speed sensor today . Abs light ,traction lights were on and cruise did not work . All good. Deep snow and ice may have got me
  17. Jan 30, 2019 at 6:15 PM
    Welcome @Metmancd ! Not a difficult job unless the wheel speed sensors are rusted in like post# 15
    Post a few pics of your JKU and future mods to come
