ABS Traction control light followed by grinding noise when applying brakes
Discussion in 'Wrangler JK (2007-2017)' started by Slowrida, Mar 20, 2022.
  1. Mar 20, 2022 at 10:04 AM
    Slowrida
    Slowrida [OP] New Member
    Robert
    2017 jeep Wrangler
    Hello everyone, does anyone have or have had an issue with the ABS and Traction Control light on followed by a grinding noise when applying the brakes on a jk 2017.
  2. Mar 20, 2022 at 10:12 AM
    Have you checked the brakes?
    Sounds like you need new pads
    Bob and Slowrida[OP] like this.
  3. Mar 20, 2022 at 3:54 PM
    Slowrida
    Robert
    2017 jeep Wrangler
    Yeah, it's not the brakes; there new
  4. Mar 20, 2022 at 5:55 PM
    And the ABS sensor??
  5. Mar 20, 2022 at 7:03 PM
    Brakes should not grind. Check for rust, calipers for proper function, rotor surface, make sure slide pins move freely and lubed. Scan for codes in case a wheel speed sensor failed or line was tweaked
  6. Mar 21, 2022 at 8:42 AM
    Slowrida
    Robert
    2017 jeep Wrangler
    Thank you so much
