AC not working
Discussion in 'General Jeep Discussion' started by Adam39601, Dec 3, 2017.
  1. Dec 3, 2017 at 3:17 PM
    Adam39601
    Adam
    2001 jeep wrangler sport
    Got a question on my 01 Wrangler TJ 4.0. The air conditioner is not cutting on the blow cold compressor cutting on but it's like it why can't I turn off the heat? I turn it all the way to AC but the heat still blows. Any ideas on what to check? thank you
  2. Dec 3, 2017 at 3:26 PM
    Start with the Blend Door. Might be a disconnected cable, or stuck.
  3. Dec 3, 2017 at 6:56 PM
    Check the vacuum line my 98 tj had a bad spot under the battery was not holding vacuum.
