Advice on moving axles under the springs?
Discussion in 'Wrangler YJ (1986-1995)' started by Jeepdood, May 11, 2018.
  1. May 11, 2018 at 5:35 AM
    Jeepdood
    Jeepdood [OP] Active Member
    95 wrangler
    None yet
    In order to to move front & rear axles to UNDER the springs instead of above, what exactly needs to be done ?
    Also, when i first start up I usually get a slight smell of fuel for a second or two. Why..... ?
    Ideas ? Thanx guys
  2. May 11, 2018 at 6:40 AM
    Get this one: http://www.rocky-road.com/yj-soa.html I know it says 35s, but I bet you can run this kit and 37s with a little rubbing under full flex. If you run this kit with Highline fenders you will be able run 38s with little or no rubbing under full flex. I have it on my CJ and 37x14.50x15s and I have no rubbing.
    Bob and aggrex like this.
