Affordable 4-6" lift for YJ?
Discussion in 'Suspension' started by Jeepdood, May 7, 2018.
  1. May 7, 2018 at 4:47 AM
    Jeepdood
    Jeepdood [OP] Active Member
    95 wrangler
    None yet
    Looking for an affordable 4 - 6 " lift
    For my 95 yj new or used.
    Ideas ?
  2. May 7, 2018 at 5:10 AM
    Welcome! Not too keen on used lifts unless you know more about the lift and lifts in general as the miscellaneous or missing parts that might not play well with each other. Check out an online vender like Quadratec to start you search. Post up what you decide as there are some YJ members here that can assist you. And pics of your YJ.....Save the squares...LOL
  3. May 7, 2018 at 8:28 AM
    For 4in and bigger the Rubicon express lifts are probably the best on the Market.
    At 4-6in of lift you'll need a SYE kit and rear driveshaft as well.
