Air Suspension
Discussion in 'Grand Cherokee' started by KOMAL102, Jan 14, 2026.
  1. Jan 14, 2026 at 4:30 PM
    KOMAL102
    KOMAL102 [OP] New Member
    KO
    2018 Grand Cherokee
    Hi,
    My first time on the forum. I have a 2018 GC. The air suspension isn't working. looks like the compressor will need to be replaced. MOPAR offers a new compressor for $1900+, rebuilt for $900+ and aftermarket compressors are in the $400 range. Any thoughts or experience you can share. Thanks KOMAL102
  2. Jan 23, 2026 at 5:39 AM
    fearless96
    fearless96 Member
    honestly stay away from the cheap $400 aftermarket units because they usually fail in less than a year and sound like a jackhammer behind your fender the $900 rebuilt option from a place like rebuild master tech is the best middle ground since they use oem cores and often upgrade the internal piston to outlast the mopar original
    if you do it yourself make sure you check your rear airbags for leaks first because a tiny leak is usually what kills the compressor by making it run 24/7 also remember that this system needs to be refilled with nitrogen not just regular air or it'll freeze up and fail the first time it gets cold outside
