Amp difference in Alternator
Discussion in 'Electrical' started by Jrgabriel, Nov 18, 2019.
  1. Nov 18, 2019 at 8:09 PM
    Jrgabriel
    Question - The original alternator for my Jeep is a 220 amp alternator. When they replaced it they used a 180 amp. What issues can come with that?
    Billy1234 likes this.
  2. Nov 19, 2019 at 12:34 PM
    You should be able to turn on all your vehicle electrics while the engine is running and not get a discharge. If you do get a discharge, you also got screwed. Not sure but the 220 amp alternator could have been a factory upgrade for something like a winch that could add on.
    Since the larger alternator would cost more and if you don't really need it, you should have saved a few bucks on the repair.
  3. Nov 19, 2019 at 6:28 PM
    JGC may have been optioned with the HD alternator or equipped with high draw OEM accessories. IMO the 180 is not likely to cause immediate issues.
