AWD or 4WD ?
Discussion in 'Cherokee' started by TinyInkognegroT, May 26, 2019.
  1. May 26, 2019 at 7:35 AM
    TinyInkognegroT
    Is my vehicle AWD or 4WD? When I'm just driving around normally, should I have it in 4 high, neutral, or 4 Low?
  2. May 26, 2019 at 7:40 AM
    On paved roads it should never be in 4L. Post a pic of your gear selector to get the best answer
  3. May 26, 2019 at 7:42 AM
    What options do you have for 4wd? If you have a Full Time 4wd option you can drive around in that any time you want.
    If you just have Part time 4wd or 4 HI that is to be used on terrain where the tires can slip (dirt/gravel/snow/etc).
    4lo is for when you need slow speed with more torque, climbing a steep grade, climbing up/over an object, etc.
  4. May 26, 2019 at 7:51 AM
    TinyInkognegroT
  5. May 26, 2019 at 7:58 AM
    Full-Time 4WD system for all weather/road use. 4LOW for trail/off-road use.
  6. May 26, 2019 at 8:03 AM
    TinyInkognegroT
    OK thanks !!
