AX-5 Transmission
Discussion in 'Wrangler YJ (1986-1995)' started by gufnstin, Oct 4, 2021.
  1. Oct 4, 2021 at 11:31 PM
    gufnstin
    gufnstin [OP] New Member
    None yet lookig at 1997 Wrangler
    N/A
    I have heard that the AX-5 transmission is basically junk !! Is that with oversize tires or just in general ???
  2. Oct 5, 2021 at 12:12 AM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    AX-5 was a pretty light duty transmission. OK for a stock 2.5 cid 4 cyl engine used for commuting. Not strong enough for higher displacement engines, bigger tires or any real off-roading.
    Brass syncros is potentially damaged with long term use of any gl-5 gear lube containing sulfur.
    Problems also occurred too often with the 5th gear snap ring.
  3. Oct 7, 2021 at 11:33 PM
    gufnstin
    N/A
    Thank you Groundfault. And from your response, I have to guess that mileage enters the equation also !!!
