Ax15 rebuild
Discussion in 'Wrangler YJ (1986-1995)' started by 1991yj, Feb 17, 2019.
  1. Feb 17, 2019 at 6:21 PM
    1991yj
    1991yj [OP] New Member
    Adam
    1991 red wrangler
    Hey, so I was wondering what the best rebuild kit would be for the ax15 5 speed transmission? Thanks in advanced.
  2. Feb 17, 2019 at 6:41 PM
    Summitracing sells the Crown and USA standard, while East Coast Gear Supply sells Motive. I can't tell you that one kit is better than the other, only that I have used parts from all 3 companies in my jeeps and I have no problems with any of them. I would send an email to Novak-adapters and ask them. They are expert with trannys and Tcases. Or call them . . . they are very friendly on the phone.
    https://www.novak-adapt.com/
