Backfiring on downshift
Discussion in 'Wrangler YJ (1986-1995)' started by Johnheard361, Jun 1, 2019.
  1. Jun 1, 2019 at 8:46 AM
    Johnheard361
    Johnheard361 [OP] New Member
    95 yj 2.5l
    Have a 95 jeep with 2.5 and when I downshift, I have suddenly gotten a backfire when I do. Sounds like glass packs exhaust almost. New plugs, wires, rotor and cap....no change
  2. Jun 1, 2019 at 9:39 AM
    Welcome @Johnheard361 back in the carb days over rich fuel mix was culprit and/or advanced timing. Hang on for some other areas to inspect to pinpoint the problem.
  3. Jun 1, 2019 at 12:10 PM
    check for codes.
    Any exhaust leaks?
    Check for vacuum leaks.
  4. Jun 1, 2019 at 12:15 PM
    Advance timing was usually the culprit back in the day of carburetors
  5. Jun 1, 2019 at 3:40 PM
    boondoc89 Well-Known Member
    Beat me to the exhaust leaks. I bet that's what it is
  6. Feb 28, 2020 at 8:16 AM
    Ron_48
    Ron_48 New Member
    91 yj soft top with half doors
    Make sure plug wires match fireing order. and #1 plug wire is on #1 distributor cap. Good luck
