Backspacing and lift for narrow track CJ 7
Discussion in 'Wheels & Tires' started by pastor scott, Oct 8, 2018.
  1. Oct 8, 2018 at 4:30 PM
    pastor scott
    scott
    1978 CJ 7
    none right now
    So I'm ready to buy my lift tires and wheels
    Here is my questions
    Going with 33X12.50R15 or 33X10.50R15
    What back spacing do I need. This is a narrow track cj 7
    Also what lift. 2.5 or 4. Will be off roading
    What say u experts
    Thanks guys
    Ps Scott
  2. Oct 8, 2018 at 5:43 PM
    I would think 2.5" should offer good clearance for the tires, while keeping the CG low. Im not all that familiar with the CJ, but I think @OFFGRID is.
    Bob and JKBob 25 like this.
  3. Oct 9, 2018 at 8:19 AM
    pastor scott
    scott
    1978 CJ 7
    none right now
    Totally confused here
    Have a 78 CJ 7 narrow track. Need to get wheels to fit 33X12.50R15 for off road . I'm torn between 3.75 4.00 or 4.50 .Back spacing. Help
    Ps Scott
  4. Oct 9, 2018 at 9:03 AM
    I would install old man emu 2.5in springs and get 5 inch shakles for another inch of lift. No drop pitman arm needed. Run 15x8 or i prefer especially for the narrow track 15x10 wheels with no more than 3.75 back space and 33x12.5x15 tires. My buddy runs this same set-up with Metalcloak's Highline fenders and he clears 36x12.50x15s with no rubbing under full flex. You should be good with 33s and stock fenders.
  5. Oct 9, 2018 at 9:15 AM
    3.75 inches and no more. your tires will be close to rubbing the springs on a narrow track axle if you too much back space. My 37s get all up into my springs with 3.75in backspace and I have widetrack axles with 2 more inches each side of the spring in length..
  6. Dec 2, 2021 at 6:38 PM
    venabl1447
    venabl1447 New Member
    @OFFGRID
    I was reading through you information above and I’m in the same situation with a 1979 CJ7 Narrow Track. I’m wanting to run 33x12.5x15 tires and looking for the best configuration that adds the least amount of lift with no rubbing. I won’t be doing any hard core off-roading. Here is what I’ve spec’s out, do you think this will suffice?
    2.5” suspension lift
    1.0” body lift
    10x15 wheels with 3.75” backspacing
    33x12.5x15 tires
    Shackles - not sure what I need to get here??? Do I get the same shackles for front and back?
    Do I need to do anything with sway bar, pitman arm or any other suspension mods to keep things in tact?
    Appreciate any help, this is my first project on a CJ and don’t have any experience….YET!
    Thanks,
    Venabl
