Bad speedo and heat/ac
Discussion in 'General Jeep Discussion' started by Thatsthespirit, Sep 14, 2019.
  1. Sep 14, 2019 at 6:20 AM
    Thatsthespirit
    Thatsthespirit [OP] To be clear I know JACK about vehicles.
    Rocket
    Indiana
    2001 Jeep Grand Cherokee 4.0
    I have a tree air freshener that's "black ice" scent. LOL
    Hi, I have a 2000 Jeep Grand Cherokee Loredo 4.0. I just got it and 1) the speedometer don't work but all the other gauges do. Also my ac/heat does not work. When turned on it barely blows. And need advice on most effective emovingway to remove bad odors permanently. Any input is greatly appreciated, thanks.
  2. Sep 14, 2019 at 6:39 AM
    a new to you jeep,
    when you start jeep (every start) does the CEL come on for @3 seconds then go out?
    Do you have a scanner ?
    I am suspecting the CEL is on steady - SO take advantage of the free scans at autozone advance auto orielys et al - copy the codes down and post here someone will interpret and advise...
    ac/heat - this is HVAC , need to know which system you have - dials or are there LEDs with temp selections.
    exactly what does not work?
    the blower/fan?
    Cant select air discharge - feet, dash, defrost?
    Cant selsect temp?
    Thatsthespirit[OP] likes this.
  3. Sep 14, 2019 at 6:54 AM
    Thatsthespirit
    Rocket
    Indiana
    No dont have a scanner. I'm not very car savy sorry. What do you mean by does the cel come on ?
    When I tried turning the cold air on it blew for a slight second then almost died out completely and blew out a funky smell. The car has odors issues so maybe it's from that but in my opinion it was a smoke/mechanical smell.
    I get it back Tuesday and I'll get AutoZone to scan it and post the code. Thanks !
  4. Sep 14, 2019 at 7:29 AM
    CEL is Check Eng Light . definitely auto zone et al for a scan :thumbsup:
    I will try to get a list/plan together for this, the gang here will help.
  5. Sep 14, 2019 at 7:48 AM
    Thatsthespirit
    Rocket
    Indiana
    That would be much appreciated. Thanks you so much. Bc after buying it,fixing 2 new tires, a few body panels and still needing to fix the heater and money's getting thin.
  6. Sep 14, 2019 at 9:09 AM
    Thatsthespirit
    Rocket
    Indiana
    @Awrench The CEL stays on the whole time I'm driving it. I do not have the digital climate control, just the standard manual controls. The air blew somewhat regular for a few seconds then almost stopped blowing air. It was barely doing anything. There was a funky smell (some from my vehicles odor from sitting so long) but also there seemed to be a electrical smell I guess.
