BAMF Gladiator Front Stubby Bumper.
Discussion in 'Gladiator (2020+)' started by Bayareametalfab, Oct 28, 2020.
  1. Oct 28, 2020 at 11:57 AM
    Bayareametalfab
    Bayareametalfab [OP] Member
    Jerry
    After building Toyota parts for a decade. We decided to buy a 2020 JEEP Gladiator to jump into the JEEP market.
    Thankfully JEEP wranglers from the JK/JL to the current JT Gladiator have the same mounting points for the front bumper.
    In the Toyota world we are known for making stout products that can take a punishment. Our JEEP products will be the same.
    We only use American made steel, And proudly manufacture everything 100% inhouse. Even our powder coating is done in house giving you a better finished product. We use a thermoplastic coating with a reverse texture on our products that can be field repaired with a torch or heat gun "yeah you can fix our powder coat with FIRE"
    The winch plate and mounting points on our bumpers are made from .250" HRPO A-36 mild steel. Our recovery points are Laser cut .750" SSAB USA plate steel that are tumbled in ceramic media for 18 hours to soften the edges then welded 5" along the winch plate with the pulling point near center of the frame rails. The winch plate is recessed down between the frame rails allowing proper air flow behind the grille. The outer skin is .188" HRPO plate steel with a recessed hawse fairlead location and cube light pockets. The bumper measures 45" at is widest point and tapers in to 41" and the bottom corners allowing for 40" tires are stock height (well if you can clear the rest of the stuff)
    It can be ordered with or without a hoop.
    https://www.bayareametalfab.com/JEEP-Wrangler-Gladiator-Stubby-Winch-Bumper_p_162.html
    20201023_183257-01.jpg 20201023_183250-01.jpg 20201023_183312-01.jpg 20201023_183241-01.jpg 20201023_183321-01.jpg 20201025_182036-01.jpg 20201025_182015-01.jpg 20201021_175406-01.jpg 20201021_175238-01.jpg 20201025_182036-02.jpg
    [miko] likes this.
  2. Oct 29, 2020 at 5:41 AM
    robertcladner55
    robertcladner55 New Member
    Robert
    3403 Grove Street Bethpage, NY 11714
    2010 Jeep JK
    could that ARB bumper work on a 2010 JK? Thanks for including us in this post! Nice job Bayareametalfab.
  3. Oct 29, 2020 at 6:00 AM
    Bayareametalfab
    Jerry
    I'm pretty sure it will bolt right up but I would have to check it as were pretty new to JEEP parts.
  4. Oct 29, 2020 at 7:18 AM
    I could swear I saw this guy on COPS :anonymous:
    And we know right where to pick him up
  5. Oct 29, 2020 at 4:04 PM
    TJ4me
    TJ4me Active Member
    2001 Jeep Wrangler Sahara
    Is this a post or an advertisement?
  6. Oct 29, 2020 at 5:08 PM
    Bayareametalfab
    Jerry
    Both?
  7. Nov 14, 2020 at 3:02 PM
    TangoJulietRomeo
    TangoJulietRomeo New Member
    Ethan
    2006 TJRubicon
    Currie 4” lift Currectylink Scratches and sich
    Wish you guys would get into the TJ market, honestly the Jeep market lacks a lot of the quality fabrication products that Toyota enjoys. Hopefully this takes off for you guys
  8. Nov 14, 2020 at 3:11 PM
    Any thoughts of making full width bumpers?
  9. Nov 19, 2020 at 9:35 AM
    Bayareametalfab
    Jerry
    Defiantly something we will be doing. Working on the bed rack and Dual swing rear bumper at the moment.
    Anderson and chris4x4[QUOTED] like this.
  10. Nov 22, 2020 at 7:05 AM
    Justanotherjeeper
    Ontario, Canada
    2024 4xe Rubicon
    Good enough as it is
    How about an aluminum option?
    LYFZGOOD likes this.
  11. Nov 22, 2020 at 10:16 AM
    Bayareametalfab
    Jerry
    Sorry we don't make Aluminum winch bumpers.
    Anderson likes this.
  12. Nov 23, 2020 at 11:02 AM
    Justanotherjeeper
    Ontario, Canada
    2024 4xe Rubicon
    Weight and rust are everything where I live. Something to consider.
  13. Nov 23, 2020 at 11:39 AM
    Bayareametalfab
    Jerry
    When it comes to a winch bumper strength is number one so we don't do aluminum with a winch mount.
  14. Dec 1, 2020 at 9:53 AM
    Anderson
    Anderson Well-Known Member
    Anderson
    2021 Gladiator Rubicon
    TR00PR2
    1st post here. However, a Tacoma owner as well as now a 2021 Gladiator. BAMF is a local business in my town. I’ve known Jerry for years now. My Tacoma sports most of his products because I believe in “over engineered” as a form of safety.
    I totally dig this new bumper design. It matches he lines of the front end very well. I know that I’ll have that bumper on my truck as soon as I find a buyer for my factory winch bumper.
