Best tires for my JK??
Discussion in 'Wheels & Tires' started by JKMark22, Jul 19, 2019.
  1. Jul 19, 2019 at 6:36 PM
    JKMark22
    JKMark22 [OP] Member
    2014 Jeep Jk Unlimited Sport 4dr
    With all of the tires out there along with the pro's and con's, I'm coming to the conclusion that most tires will work on my 2014 JK Unlimited Sport. Even the less expensive ones. I'm on the street 99 pct of the time. That would change once I replace my current tires that have around 60k on them. I would look to do some more off-roading on beginner trails. I'm looking at Falken Wildpeak AT3W All-Terrain tires? I feel if I were doing more difficult trails, bigger tires and lifts would be necessary. No need for a full explanation, you can keep it simple and thanks in advance...
  2. Jul 19, 2019 at 7:18 PM
    Dude.....there is no simple explanation when it comes to tires. Looks, ability, durability, etc etc. You won't be happy with any tire unless you do your own research. There's just to many tires out there. And if you read posted up threads here. It's all personal preference. Case and point. I run 2 tires. One for the Winter months. And another for the spring and summer months.
    Good luck with your venture
  3. Jul 19, 2019 at 8:31 PM
    JKMark22
    Thanks @JKBob 25 !! I agree with you and have taken that approach. I have been reading up on tires and of course, the ones I like the most are the pricey tires. That's smart to run season tire setups. I feel if I can purchase a $130 tire instead of a $175 tire I will be fine and at the end of the day, I can enjoy my Jeep. Thanks again!!
  4. Jul 19, 2019 at 8:52 PM
    AT tires will make that Sport look awesome as a DD. Get the AT that you selected with the slightly larger 32-33s if you're not ready for a lift kit. Then you can traverse the low-mid level trails with more confidence.
  5. Jul 20, 2019 at 8:13 PM
    JKMark22
    Thanks ... aggrex.
  6. May 2, 2020 at 1:47 PM
    monkeygrip
    monkeygrip Active Member
    Sid
    2015 Wrangler Sport
    That Falken AT3W is a nice tire. I think you’d be happy with them. Bigger is better, at least 285/70. They just do so much for the looks of a Jeep not to mention performance.
  7. May 10, 2020 at 7:02 PM
    autonoob
    autonoob Member
    2012 Wagoneer
    Falken Wildpeak AT3W remains stable even when driving over large pools of water, providing great confidence in braking, and cornering in wet weather conditions. If you are planning to purchase Falken tires I would recommend you check out 4wheelonline.
