Bogging down and backfiring after driving a few miles
Discussion in 'General Jeep Discussion' started by 96 cherokee country, Apr 23, 2018.
  1. Apr 23, 2018 at 5:22 AM
    96 cherokee country
    96 cherokee country [OP] New Member
    John
    1996 Jeep Cherokee Country 4.0
    Hey guys I’m new to forums but just looking for some advice. I’ve got a 96 Jeep Cherokee Country 4.0 that I’ve recently purchased. It has a new fuel pump, fuel filter, CPS, plugs, wires, cap, button, coil. I think that’s everything, but here’s my problem. It just recently started to bog down and not won’t to take fuel after driving it a few miles. It spits and sputters over 2k RPMS but only while driving. You can stop and put it in neutral or park and it takes all the fuel you want to give it. Any help would be appreciated. Thanks!
  2. Apr 23, 2018 at 7:45 AM
    Welcome! I had an issue like this years ago, and it was the vacuum advance not working. Have you check the vacuum lines?
  3. Apr 23, 2018 at 9:46 AM
    96 cherokee country
    John
    Thanks for the advice I’ll have to check that when I get home! Had someone else tell me possibly the CAT is getting clogged
  4. Apr 26, 2018 at 5:20 AM
    boondoc89 Well-Known Member
    I was thinking the O2 sensors and the CAT. The vacuum lines would be a good start. Maybe the MAF sensor is dirty??
  5. Apr 26, 2018 at 3:36 PM
    96 cherokee country
    John
    I checked vacuum lines and everything looked good so I checked fuel pressure next. It was great idling but under heavy load it dropped way down. Guess I didn’t clean the tank good enough after changing fuel pump and fuel filter. I changed filter on the rail again and all seems ok at the moment. I’m sure the pump may need changing again soon. Next time I’ll be a little more thorough. Thanks for the help guys!
    OFFGRID, JKBob 25 and chris4x4 like this.
  6. Apr 26, 2018 at 5:58 PM
    Glad you found the issue! Do you have any pictures of your Jeep?
  7. Apr 26, 2018 at 6:17 PM
    Welcome to the forum. Jumped in here alil late. Cool you found your issue. Good luck with your new Jeep.
