Brake light
Discussion in 'Wrangler TJ (1996-2006)' started by Adam39601, Dec 28, 2018.
  1. Dec 28, 2018 at 8:27 AM
    Adam39601
    Adam
    2001 jeep wrangler sport
    When I'm driving the brake light is flashing red. When stopped it's not blinking. It stops on a dime . Any thoughts of what it might be
  2. Dec 29, 2018 at 4:02 AM
    Which brake light? All 3
  3. Dec 29, 2018 at 7:28 AM
    Inspect the brake components you replaced a few months ago. Perhaps low brake fluid, air in the system, leaks, etc. Did the flashing brake light on the dash happen recently or before/after the brake parts replacement?
    TJ_abuser likes this.
  4. Dec 29, 2018 at 7:50 AM
    which brake light?
    the dash warning lights?
    the lights on back of vehicle?
  5. Jan 2, 2019 at 8:49 PM
    Adam39601
    Adam
    The dash light , it just started checked fluid its full good psi on pedal when pressed. Is there a switch on parking brake that might be off
  6. Jan 3, 2019 at 7:39 AM
    this post is going S L O W , I thought you were gone for good.
    the circuit often includes - parking brake switch. AND master cylinder.
    Check the brake fluid level in master - duh no instructions needed - I will access a wiring diagram
    and get info on adjusting switch.
