Bump stops needed if adding 1 1/2" spacers on TJ?
Discussion in 'Suspension' started by tacomawv, Jul 3, 2018.
  1. Jul 3, 2018 at 2:57 PM
    tacomawv
    tacomawv [OP] Member
    Did super fast search. got no answer. Question is do I need bump stops if I add 1 1/2 inch spacers on a tj.
  2. Jul 3, 2018 at 4:37 PM
    boondoc89 Well-Known Member
    Bump stops are always nice to have. If you don't super flex your rig I'm gonna say no. But if you do some offroad stuff and disconnect the sway bars then it's always good to have the extra protection from slamming your suspension onto the axles. I'm still running the stock bump stops even tho they are rotted and junky. Better than nothing haha. As a matter of fact one of mine is completely rotted away and it's just a bolt with the bracket underneath hahaha. I havent wheeled my rig in a while so I havent thought nothing of it
    OFFGRID, Bob, JKBob 25 and 1 other person like this.
  3. Jul 4, 2018 at 9:41 PM
    I agree with Boondoc. At only 1.5in lift your factory bump stops should cover you.
  4. Jul 5, 2018 at 6:16 PM
    tacomawv
    Thanks.
